energy poly mounts
Discussion in 'The Garage' started by surpip, Apr 10, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    has anyone used these replacement mounts? you take the clamshell apart and insert the new poly insert?
    it does not seem all that great an idea to me
    i like the tranny mout though
    also the tranny mount came with a seprate metal piece that looks like it is supposed to go under the tranny mount, do you have to install this also?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes you seperate the clamshell and put the new poly insert in. I've done it, see nothing wrong with it(though they didn't fit my s10 clamshells very well). I welded the rivet holes back up after I put the poly bushings in, they don't say to do it but I liked the idea. Whatever you do, don't use the trans mount and not the engine mounts. bad idea. Engine mount should be stiffer than your trans mount, never the other way around.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya i have both, i was just wondering about the extra metal plate that the trasnny mount came with
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale.. I did both...welded them like sled dog did... smooth and no vibrations,, and keeps the BB tame,,, I give them 4 stars
    cam
  5. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I use the motor mount inserts on my '87. They work very well and keep the BBC from wrapping up excessively. Next on my list is the tranny mount - the whole drivetrain will raise 1" under torque even with a new one.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Anyone get the motor mounts cheaper than $100? Seems like a lot for a motor mount that's really an insert.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    uhh the ones for my S10 were $45 from Jags That Run...
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Alright, I'll have to look around more. I was going to buy them but knew that had to be an outrageous price.
  9. rcamacho
    Jul 1, 2004
    1,324
    WA
    I'd try a part number search on ebay. I was able to pick up a new set secondhand for $50.
