Energy Suspension
Discussion in 'The Garage' started by MudbogAD, Jul 12, 2002.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I got some poly body mounts for my Jimmy awhile back and I was wondering if the 2 front body mounts were supposed to be smaller than the original rubbers. They are smaller in diameter and thickness. I know I bought the correct kit for it. All the others are thicker than the originals. I was just wondering. Thanks for any help.
  2. MudbogAD
    Jun 29, 2001
    672
    I guess nobody uses Energy Suspension.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i have E/S body bushings but my front two mounts are a little different. they are being moved.
  4. MudbogAD
    Jun 29, 2001
    672
    Yea, They're smaller. It's weird but it works good.
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I don't have the stock ones to look at since I had different plans when I tore the truck apart. My front mount will only be different since the stock front radiator mount will be 15" in front of my grill,LOL!!! /forums/images/icons/smirk.gif
  6. MudbogAD
    Jun 29, 2001
    672
    Wow that very interesting. /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif Cool!!
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    my grill will sit on top of the first crossmember where your p-valve is located.
    the wagon is also 9" narrower per side.and my rear body mount was moved forward 3"
  8. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    you got some work ahead of you there jeremy. /forums/images/icons/shocked.gif
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    /forums/images/icons/tongue.gif that stuff is already done,LOL
    need to patch two corners of the floor and undercoat it.
    install my body bucshings and gas tank and then IO can drop the body on. build my firewall and all my drivetrain can go in..motor,tranny,t-case and drivelines.
  10. muddysub
    Jun 23, 2001
    10,452
    489
    ooooooooooooo /forums/images/icons/ooo.gif /forums/images/icons/ooo.gif /forums/images/icons/ooo.gif cool!
