Eng. cranks but won't start (still)
Discussion in 'The Garage' started by AKbigsub, Oct 6, 2005.
  1. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    90 Suburban 350cid, w/TBI, TH400. Here are the symptoms: Check eng. light NOT on (it does work); Once running it runs fine (slight miss that has been there for a year before this problem started); starts fine the first time in the morning (so far); drive it for a short time and shut it off, try to restart it and it just cranks over, if I cycle the ignition ten times it will start. I have tried to cycle the key seven, eight, nine times and sometimes it will start but ten seems to be the magic # that works every time. I am at my wits end and need help. The fuel pump does run when I turn the ign. to the run possition (every time). I did replace the fuel pump already (new A/C Delco pump), there are no leaks in the lines that I can see, when it will not start there is no fuel coming out of the injectors. I have checked the injector plugs for change in voltage while cranking and there is a change but I would rather check for injector pulse using a node light but I don't have access to one. HELP!
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Check that the feed to the ecm is good during cranking. Check fuel pressure. Use WINaldl or similar to see what is going on with your sensors especially coolent sensor. Are you getting a spark when cranking?
    First thing I'd do is check fuel pressure and go from there.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That could be a flaky ignition module in the distributor. In addition to creating spark, it also sends pulses to the ECM so it knows when to fire the injectors.
  4. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    The ignition module was the trick. I replaced it and all is good! :D
