engaging 4x4 low(newbie question)
Discussion in 'The Garage' started by chevy17, May 26, 2004.
  1. chevy17
    chevy17 Registered Member
    May 26, 2004
    9
    hey i am new to offroading and just bought a 1990 chevy 1500 with a 4" body lift, 31 goodyear A/T and whenever i try and engage the 4 low it grinds. I got it in once and its not a loud grind but still a grind. When i engage the low i come to a stop(obviously) put it in neutral(i tried it in park, same thing) and try and engage. When i engage four high in neutral its fine, so i guess i'm just asking if there is something i'm doing wrong for the low
  2. mrk5
    Apr 20, 2004
    12,345
    1,049
    Northern Colorado
    So are you saying it won't go into 4Lo at all?
    If it's just grinding a little when you engage it, I wouldn't worry about it. Mine does that. If it is just grinding and not going into gear, then you need to check the linkage.
  3. chevy17
    May 26, 2004
    9
    yeh it goes in but getting there it just grinds a little, i asked my friend and he said also to check the linkage. But you said if its only a little grinding not to worry about it?
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    A little grinding wont hurt nothing /forums/images/graemlins/waytogo.gif Just make sure your hubs are locked, if you have manual hubs, and jam it in there /forums/images/graemlins/eek.gif
  5. mrk5
    Apr 20, 2004
    12,345
    1,049
    Northern Colorado
    Mine does it a little when I engage 4lo. I've never really worried about. If it is grinding so bad you really have to force it, then it might be a problem.
  6. chevy17
    May 26, 2004
    9
    yeh i was just a little worried because i haven't had the need really to use it yet, except once but i got freaked out by the grinding. The time i used it it just grinded a little then popped in. well thanks a lot guys i just wanted to make sure! /forums/images/graemlins/grin.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Put it in neutral and take your foot off the brake. If your rig rolls just very slightly it will allow it to go in smoothly.
  8. chevy17
    May 26, 2004
    9
    yeh thats what i think i'm going to try
    thanks a lot
  9. chevy17
    May 26, 2004
    9
  10. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    are you haveing issues because the hole in the floor for the shifter wasnt enlarged? doesnt sound like it, but its an idea to check
