Engine Accessories are all mounted finallly. FINAL update...
Discussion in 'The Garage' started by cybrfire, Sep 30, 2004.
  1. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Got a little adjusting to do on the Alt bracket. Still have to build the tensioners for the alt and york but other than that they are in their respecitve places. Lots of little brackets and support braces. Power steering basically is modified factory brackets except for one. It was an interesting project to say the least.
    Belts go,
    Crank, water pump, power steering.
    water pump, york.
    power steering, alt.
    Now i just pray everything clears the frame. If I measured correctly and didn't overlook anything it will all work out.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Re: Engine Accessories are all mounted finallly.
    Looks good. I bet it was interesting getting all those brackets and pullies to line up.
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
    John
  3. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Yeah, it was kinda difficult once I got down to the last one. I did the alt last as it was the least buried. I actually had planned to run the alt off the crank, water pump belt but with the power steering pump right there the belt wouldn't clear. I could have moved the power steering pump toward the block more but I really didn't want to alter the brackets that I had just made. They worked out so nice. The alt bracket was only partially complete so a little adjustment on it to move it back. Besides that, I think the alt will be more stable on a shorter bolt.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    WTF kind of engine is that? Distributor in front? Doesn't Chrysler do that?
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Its a Caddy motor.
    John
  6. heavy4x4
    Aug 28, 2002
    3,270
    Ah, gotcha. /forums/images/graemlins/doah.gif
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks good Kert, is that Krylon camo paint?
  8. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    Looks good from here. Custom accessory bracketry is a huge PITA IMO.
    So you decided to go ahead with the York setup.
    I've grown to prefer the distributor at the front of the motor. Easier to mess with.
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    and that fits in the front of that narrowed front end /forums/images/graemlins/yikes.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
    looks cool!
  10. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    and that fits in the front of that narrowed front end /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
    looks cool!
    No idea if it fits or not. I'll cross that bridge when I get there. /forums/images/graemlins/eek.gif
    Yep, Krylon paint and after the poll the other day I decided to go ahead with the york. I have a small Air compressor that I can cannibalize for just about everything I need except a coalescing(sp?) filter. It's pretty much all finished except for the tensioners which I will hopefully have done tomorrow then I can snap a new shot of it complete. I ended up having to run the alternator off of the powersteering pump. I hope that works out. I can't see any reason it won't.
  11. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Well if it doesn't, you can always drop in a turbo'd cummins... /forums/images/graemlins/wink.gif
  12. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    OK, its finished.
    Belt tensioners are on.
    Little clean up and paint when I tear it all back down.
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Looks good! /forums/images/graemlins/waytogo.gif
  14. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That looks like a few hours went into that! Great work. /forums/images/graemlins/peace.gif
  15. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I would like to see the york bracket without the york installed. I just can't picture how you have it mounted there and still rotate for the tensioner without getting loose /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  16. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Looks good, Kert. Like the tensioners. What did the alternator orginially come on?
  17. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    I'll post up a pic in a little bit. Paint is drying on all the brackets now.
  18. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Alternator is off of an F550 that was destined for rescue truck service. It was basically a take off. 205 amps was enough for that rescue truck.
  19. rodzzilla
    953
    Grinnell, IA
    205 amps
    /forums/images/graemlins/eek.gif /forums/images/graemlins/shocked.gif
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    how come you went with such a big alternator? bigger the better I guess /forums/images/graemlins/doah.gif
