Engine alignment (centerline to axle)
Discussion in 'The Garage' started by 45acp, Jul 6, 2002.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    How close to perfect alignment have others been able to get the tail shaft of the transmission aligned between the frame rails? I have the engine (Cad 500) mounts set in place and I'm mounting the cross members for the TH400/Doubler and find the tail shaft is off by .020" to center line of the rear differential. The engine is setting level side to side and 5 degrees sloped to the back and looks parallel to the frame. The frame has so many twists and bends at this point it is hard to tell where to measure from. Any one with experience, I would appreciate your input as to how close you got the tail shaft centered.
    /forums/images/icons/confused.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'd be surprised if GM got it any more accurate than that. 20 thou ain't much...
    Rene
  3. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Rene, How much effect does it have on driveline vibration?
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'm not sure how you could quanitfy that...but I am sure there is more lateral deflection in your spring bushings than .020".
    There is also torsional deflection in the engine and tranny mounts due to torque.
    Lastly the datum you are measuring from is also not the most reliable.Too many variables in manufacturing as well as 20 plus years of service means the edge of your frame is not a reliable enough datum to use. Ideally I would drop a plumb line from the center of the front balancer, another plumb line from the center of the tailshaft and a third from the center of the diff. All three points should line up on the floor when everything is centered. Make sure the truck is sitting level front and rear though.
    I am pretty sure that 20 thou isn't worth worrying about though.
    Rene
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I agree with what Rene said about the engine and tranny mounts.
    Over time and the years, the stock rubber mounts are subjected to much wear and tear, no just to the weather but also to the oils and other fluids from the vehicle.
    These fluids such as the oils, etc. are/have been known to soften some of the rubber compounds. Such softening and all the vibrations they are accustomed to will make the motor/tranny/t-case all settle in different locations than what the factory had spec'ed them to.
    So your .020" is not much at all to worry about. That's basically like what, a dime or smaller? I doubt something that thin can or will affect the driveline any worse than if it was sitting dead-on straight as the factory. /forums/images/icons/wink.gif
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I doubt they were ever that straight from the factory Wes...GM getting the drivetrain aligned within 20 thou? /forums/images/icons/smirk.gif I wouldn't bet on it.
    Rene
  7. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Rene, Thanks, I went ahead and finished the crossmember that I was building and left it about .020 to .030 off center. If I tried to get the last little bit it would have put a bind on the front engine mounts. I just didn't want to get down the road a year from now and wish I had done a better job.
  8. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Human hair is .004 so you're only off 5 hairs or so.... /forums/images/icons/wink.gif /forums/images/icons/grin.gif /forums/images/icons/cool.gif
  9. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
  10. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    a tenth of a quarter inch, hmmmm. You get almost an inch just turning, I don't see a problem, as for angles, that's what a driveline is for /forums/images/icons/grin.gif
