engine angle
Discussion in 'The Garage' started by 86chevybanshee, Jun 19, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    im trying to make a crossmember for my truck.
    i need to know if there is a certain angle the motor is supposed to be at
    thanks
    oh and its a tbi 4.3 s10
  2. dyeager535
    26,979
    No response from those that have played around with mounting engines differently than stock?
    I'll take a stab. Use the TB mounting surface on the intake, and use a level. That surface should be flat.
    Anyone disagree?
    Noticed that on the carbed intakes, the carb surface is not "inline" with the rake of the engine, which indicates to me that GM made the carb/TB surface parallel in relation to the ground.
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    well i asked a guy at work today and he sed that the yoke on the transfercase should be 4* and whatever the angle of the motor is, is what angle it should be.
    does that make sense?
