engine angle
Discussion in 'The Garage' started by 1979jimmy350, Aug 15, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i am doing a custom engine install and am getting ready to mount the tranny, what is a good angle to have the engine sit at in relation to the frame?
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    set it so the carb mounting flange on the intake is level
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Don't worry too much about your engine angle. Get your trans/t-case where you want it to be so you can have good UJ angles.
    As long as the dizzy ain't touching the bulkhead(or likely too) and your fan ain't going to cut a hole in your rad you'll be ok.
  4. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    The stock angle for the driveline in my in my K10 is tilted 6* back with respect to the frame.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Back from my race car days you want the carb surface between 2-4* tilted backward.
