engine backfiring,please help
Discussion in 'The Garage' started by jones, Jan 11, 2007.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    i really don't have the specs for this engine other than it's a recent rebuild.i was told it was a .030 over 350,but it actually turned out to be a 400.i haven't pulled the heads to be sure it's bored.it's backfiring through the exhaust and the carb.i haven't found any vacuum leaks,the headers are snug(no leaks there),i've advanced and retarded the timing via the distributor to no avail.it's got a stock type fuel pump,holley 650 double pumper,882 heads(u/k if they've been worked over.)i'm pulling my hair out trying to get it running right.pleeeeeeeeease help!thanks!
  2. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    sounds like timing... are you sure its right? it could be way off
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    my truck has been having some small backfiring issues lately too...when does your's do it? Mine does it when I get into the throttle (in 1st) and when I let off a little it'll sort of pop...
  4. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    When is it back firing? if it pops out the intake under accleration than it's probably lean, if it pops both out of the exhaust and the intake simultaniously than you may have a valve problem, likely a broken valve spring. Valvetrain problems always cause the engine to run real rough especially at an idle and will cause it to backfire as the engine speed is raised or engine loaded down.
    Please post more specifics and I can help you more.
  5. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Choked plugs will also cause merry mayhem. A front mount PCV on a stock intake can (depending on engine age, rocker covers etc) can foul No 2 after sometime.
    What did your plugs tell you when you pulled them?
  6. jones
    May 17, 2004
    379
    IONIA,MI USA
    more specs:edelbrock intake,PCV into valve cover towards the back of the engine,pass.side.idles fairly smooth,starts popping through exhaust at op.temp,though not constantly.bleeping the throttle gets more exhaust popping,then a good pop through the carb.plugs are new as are the wires.plus not getting to hot or fouling(black sooty)they were wet with gas:eek1: ,hopefully not a bad thing.hope that helps,thanks!
  7. 58 apache
    Aug 26, 2006
    377
    sounds like timing is 180 out
  8. bigblock72
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    Pop those valve covers off real quick and make sure no broken rockers or valve springs. Usually a valve spring will break the second coil down and may be hard to see. If the timing were 180 out it wouldn't start, you've replaced plugs and wires and moved the distributor all over with no change so that rules out spark issues, a carb wouldn't normally cause the backfiring problem. Time to move on to valvetrain.
  9. jones
    May 17, 2004
    379
    IONIA,MI USA
    thanks for all the suggestions,guys.it's very much appreciated.i'll make time this weekend to pull the covers.aside from checking the springs for cracks,should i check for any thing else?would it do the same thing if the rockers were to tight?how do i go about tuning aholley carb(650 double pump;model# u/k)?
