engine balancing questions
Discussion in '1982-Present GM Diesel' started by colbystephens, May 2, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i had my engine balanced. being that it is externally balanced, they added some weight to my flexplate by adding some "beads of welding" - that's good knowledgeable terminology for some melted metal stuff to add weight in certain places on the flexplate. well, here i am going to swap to the sm465 in about 3 months and i'm curious to know how much this swap might affect the longevity of my engine because i'll be losing the balanced flexplate for an unbalanced flywheel. my machinist said he could attempt to match balance the flywheel to my current flexplate, but that he couldn't guarantee it would be as perfect as when he's got the whole crank/piston/harmonic balancer/flywheel assembly - makes sense. anyway, he says it will probably run about $100 to match balance the flywheel. is this worth it? lets hear some tech discussion/theory behind all these responses please!
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Why the delete Craig?
    Rene
  3. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    Deleted my response after re-reading Colby's post, I wasn't adding anything pertinent. I needs to learn me to reads better. And I forgot to leave a reason. My bad.
