engine blocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Apr 2, 2002.
    anyone know of a site that lists what blocks can be swaped with each other without installing new mounts... and what blocks are used ...(ex.. 305, 350, ...etc) what bores are in the same block... i'll be replacing my 350 and i'm wanting to go with the biggest block i can find in a bone yard that's still usable.... thanks
  1. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    You could use any small or big block chevy & use the same mounts. They are all the same. If you were wanting to stick with a small block, the 400 is the largest displacement chevy ever made.
  2. BAD LUCK 79'
    BAD LUCK 79' 1/2 ton status
    Oct 8, 2001
    130
    Panama city Florida
    thanks .. that helps out alot... now it's time to find a 400 block....woo hoo...
