Engine Blowing oil I think
Discussion in 'The Garage' started by CaveBlazin, Jun 19, 2002.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Well here's the story. I have'nt started the ole Blazer in about 2 weeks and When I did I noticed some black spots on the ground below my exhaust so I gave it a little gas and it sprayed out more after about 10 minutes of running I went back out and it stopped the spraying. A buddy of mine said it could be a warped head or a crack in the block is he over reacting and it was just condensation any idea's please(that's all I need is a cracked block). O yea also it seem to have picked up a miss I have'nt got to diagnose that yet but would it have anything to do with the black spots ANY IDEAS would be greatly appreciated....
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I almost sounds like bad rings or valve stem seals. There are really too many things that it could be to make a very accurate diagnosis without actually seeing it.
    John
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Im glad someone had an idea I was gettin worried I might have to take it to a shop NOWAY!!!
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    whats a shop?
    NITRO
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    ALL my cars do this. It is condensation in the exhaust. The sooty exhaust pipes mix with the water condensation on startup and "spit" out the exhaust giving the illusion it is oil.
    My 97 Mitsubishi, 85 Porsche, my 96 Isuzu, and my Blazer all do this.
    I also checked my friends BRAND NEW Isuzu, yep... it does it too!
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    That makes me feel a little better now just gotta find out why she is missing could be a number of things but thats the easy part...
  7. procomp94
    procomp94 Registered Member
    May 16, 2002
    64
    Colorado Springs
    Both mine do it to and if you get a little on your fingers and smell it you'll most likely find that it doesn't smell like oil but probably gas and water (soot and condensation). And as far as the missing goes, drive it a little more often and change or clean the plugs. Chevy's weren't made to be parked in a garage for ever.
