Engine Bugs
Discussion in 'The Garage' started by k5freak44, Jan 10, 2006.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Well i thot i solved my engine porobs but they are back and in full force.
    What would cause
    - I start my car, it fires right up and as soon as i put it into gear it dies.
    -When i give it some gas it either dies or bogs down hooribly causing VERY poor acceleration.
    Any ideas, im guna do a pressure test when i can get around to it, b/c i think i might have a blown or leaky head gasket.
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    have you done the simple stuff change fuel filter check for vacum leaks ?
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    forgot to list it but im runnin a 350 TBI engine
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check trouble codes?
  5. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i havent yet, ill checkk them this week
  6. dyeager535
    26,980
    How is idle? If idle isn't smooth or low as it should be, I'd be looking for a vacuum line problem.
  7. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    idles finee its right after i pop it in drive or right when i give it some gas is when it gets nasty
  8. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    so I assume it has a 700r4 trans? does it bog down in park? if so then it's all engine but if it revs fine in park then you could have a stuck lockup valve in your trans. just my .02
  9. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    idles just fine
    these are my sypmtoms
    -white smoke on startup
    -nasty exhaust smell
    -low and dirty coolant
    -runs like poo
    head gasket?
    im guna do a pressure test tomorrow
