Engine Choice
Discussion in 'The Garage' started by chevyman562, Nov 7, 2004.
  1. chevyman562
    chevyman562 Registered Member
    Feb 2, 2003
    46
    The lovely LBC
    I am going to start building a motor for my truck. I can't decide between a 383 stroker or a 454 big-block. I have a running 400 SB in my garage. I am looking for the most torque I can get. Is a stroker that much better on gas mialge than a big-block? What about cost? Thanks.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A Big Block may cost alittle more too build, but once you've had one, everything else feels under powered. The next K5 I build will have a Big Block !!!!!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can't chose either a stroker , or a Big Block and worry about cost . Either one will cost you . 400 SB with good heads ( steam holes drilled ) , good cooling , and good induction/exhaust will be allright if you ask me . Of course if money is NO object I'd do the stroker because there lighter physically , and more compact dimensions /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    My buddy's father is an engine builder, and he always says it's better to go with a big block. His reasoning was that a 454 would perform just as well as a 383, and you'd be stressing a 454 much less.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Car Craft just did a comparo between a 454BB and a 454SB-the small block made more hp and torque-I guessed wrong on that winner!
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Big Block stroker /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    If gas cost is not a problem I would go with a 454. Cost a lot less to make torque from a 454 than it does to make it from a stroker small block.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There is always more torque with extra cubic inches . There are many variables between those motors , but I'd be willing to bet that when two engines are the same cubic inches , the one that has a lighter rotating assembly will make more power and torque /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I would think the stroked small block wouldn't last as long though. Relieabilty is a issue for me. /forums/images/graemlins/thinking.gif
  9. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I'm actually getting better gas mileage when I swapped out the 350 for a 454. In the small blocks you'll have to put a lot more $$$ into them to perform like a stock big block IMHO.
  10. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Build the 400 and use a set of longer 5.7 inch 350 rods. 400s are good engines, they just need a good 4 core rad to cool. 400s can easily make wicked torque and will help keep the weight down as compared to a big block.
  11. chevyman562
    Feb 2, 2003
    46
    The lovely LBC
    Thanks for all the help guy's! I think I am going to stick with the 400 SB.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Run the 400....
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what did they do to the BBC to make it lose?
    big inches always win doesn't matter if you get them by bore or stroke
  14. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Hell yeah. /forums/images/graemlins/waytogo.gif Best of both worlds.
  15. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You could stroke the 400 /forums/images/graemlins/peace.gif Only problem is its an expensive motor. But the 400 with good heads,intake, and exhuast with a matching cam will have good power.
    Later
  16. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    When I sawapped in a stock 400 small block from a 78 suburban into my 74 K20 in place of the stock 454 from a 74 chevelle that was making scary noises(turned out to be broken piston skirts,and loose wrist pins)--I noticed very little if any real difference in power,and the front of the truck felt noticeably lighter--granted the 454 I removed had seen better days,but it ran pretty good--the 400 was stuffed in quite hastily--I didnt even put a timing chain or oil pump in it(I wish I did now)but it still runs fairly well,but its due for a rebuild too.I think the 400 is the only small block that can stand ground against a big block,a 400 or a 454 are the kings of tourque in a GM truck,unless you swap a Caddy motor into it.. /forums/images/graemlins/crazy.gif
