Engine CID ID
Discussion in 'The Garage' started by BlaKK54Speed, Jan 1, 2007.
  1. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    how can i tell if i have a 350 or a 305? owner told me it was a 350 but im not so sure. vin says its a 305. looks awful original. where can i find an engine id tag or what can i see for differences???? any help is greatly appreciated.
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I found the numbers on the front...right behind the alternator there is a machined pad where the head and block meet. I wire brushed that part and looked up the numbers on Mortec.
    Rene
  4. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    EXCELLENT RESOURSE INFO :bow: :bow: :bow: :bow: !!
  5. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    ill go look right now and see where they are.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the numbers on mortec are on the rear of the block, between the head and the bellhousing. should be on the drivers side of the engine.
    just judging by the exhaust manifolds, and the fact that the VIN says its a 305, it probably is.
  7. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    so yea.....cant get to the numbers on the block, i can feel them with my fingers and just barely start to see the last numbers but there is a wire loom right over them, plus oil and grease and there is a retainer about an inch away so i cant move the wire loom to even see them. man i am so mad right now. how hard can it really be to id the damn thing
  8. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i want to say its a 305, it just looks too original not to be
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Prolly faster to pull the oilpan off...305 has a 3.75" bore versus the 350's 4" bore.
    Rene
  10. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    yea i guess that would give it away right away. i do need an oil pan gasket any way
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Perfect excuse. My VIN also said 305 when i ran it, and i had the same trouble you did getting the numbers. I pulled the pan because I was doing a rear main seal and found 4 bolt mains, check the bore and it was just proud of 4"...
    When i finally did get the numbers off the block it just comfirmed what i already knew, 4 bolt main 350.
    Rene
  12. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    wow that would be nice if i could do the same. doubt it will happen though. with my luck
  13. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The one and only 305 I ever had, was external balance. The harmonic balancer had offset weiight cast into it. Real easy to see on the back of the balancer.:confused:
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no 305 has ever been external balanced, they're all neutral balanced. save for the 87+ 1 pc RMS versions, which have a counterbalanced flywheel/flexplate (due to the lack of material to remove for balancing in the RMS area) , and a neutral balanced dampner.
  15. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    X2 305's or 350's aren't externally balanced. Only the 400 had the "notched" balancer.
  16. dyeager535
    26,979
    Do this. Surefire, as long as the block has never been decked. They are called "suffix codes". This can be accomplished (apparently) on all engines when installed, but it may be more difficult depending on equipment in the way.
  17. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Well, I know the motor was a 305. I tried to use the balancer off my 70 350,so all the accessory pulleys would line up. It shook like a bastard! I pulled it all back apart, and compared balancers. The 350 unit was flat on the backside, and the 305 was channeled, except for one area that looked like a big square. The 305 came out of a 78 Impala, BTW. It was NOT fun changing over all the brackets and pulleys.:(
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    78 Impala... could've very well been a 400, since they were produced from '70-'80. that would have an externally balanced balancer and flywheel. :thinking:
  19. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    The reason I said I KNOW it was a 305, is cause I had to replace head gaskets 1 year after I installed it.:confused:
  20. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i already looked behind the alternator, there arent any plates or stampings anywhere on the head or block there. i looked hard too
