ENGINE CLEANER
Discussion in 'The Garage' started by CHEVY 4WD, Aug 30, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    what is the best thing to use to clean a engine? Somthing that wont messup(including paint) anything up or dry out gaskets
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Engine cleaner /forums/images/icons/wink.gif I think there's a line out called Engine Brite that works fairly well.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how tough is it though haha..mines never been cleaned since 85.. /forums/images/icons/blush.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've never found anything that works better than Gunk Engine Brite Heavy Duty Engine Degreaser for getting off the really nasty stuff. The only downside is that your truck will smell like the engine cleaner for about a week. It's pretty smelly stuff, but it really gets the job done!
    For light duty cleanings, Gunk Foaming Engine Brite works very well. It isn't as good on really grimy build-up, but it also doesn't stink nearly as much. /forums/images/icons/cool.gif
    Oh, the best thing is that either one is only something like $1.37 per can at Walmart. /forums/images/icons/cool.gif
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oven cleaner works real good also. It was the only thing that I could find that cleaned up my tranny.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    dosent oven cleaner strip paint?
  7. Can Can
    15,555
    146
    Cochrane, Alberta, Canada
    Make sure when you spray down the engine you either cover your distributor or keep the water away from it. Cool water on a hot dist. cap can cause it to crack. Ask me how I know...... /forums/images/icons/tongue.gif /forums/images/icons/wink.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea thats something i was wondering about ...how do you go about applying the cleaner to clean it?
  9. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    It usually comes in an aerosol can.
    Wisk laundry detergent, wire brush, and a steam cleaner work great, just be sure you cover everything that doesn't like water.
  10. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    how do you know? /forums/images/icons/smile.gif
    jacob
  11. k5ntexas
    Oct 29, 2001
    2,517
    don't you just hate it when those people that pad posts. ya know what i mean. i mean geez are they THAT bored. *coughyescough*. lol. later.
    jacob
  12. Can Can
    15,555
    146
    With your engine cold, spray the block and anyhting else dirty in the engine bay with a good coat of the engine cleaner. The foamy kind works best because it actually clings to the grime. Like I said before, stay away from the dist. cap and the if you have an open air filter setup, don't spray that either.
    STart your rig up and drive her down to the closest DIY car wash(or if you have a pressure washer drive around the block a couple of times to get the engine warm). The key here is to let the engine get warm but not hot. The heat helps the cleaner work but spraying down a HOT motor can cause trouble.
    Now spray the heck out of your engine bay!!!! I would recommend leaving the engine running(no real reason for it but that's what I do /forums/images/icons/smirk.gif ).
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanx! /forums/images/icons/laugh.gif
  14. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Yeah well, if you were to listen to a buddy of mine.....
    He says that the best way to clean your valves off is to pour a teaspoon of water down your carb /forums/images/icons/shocked.gif, the shock is supposed to clean any carbon buildup off.
    Sounds like a good way to bend or break something to me /forums/images/icons/tongue.gif
  15. Can Can
    15,555
    146
    Lots of guys use that trick. But I think this post is about cleaning off the OUTSIDE of the engine......
    Another method of removing carbon buildup from the motor is to slowly suck some ATF into the combustion chamber using your PCV valve.
  16. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I cant find the GUNK foming engine brite all I can find is the heavy duty stuff BTW this stuff wont dry out gaskets or hurt any thing else right?
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, I get it at Walmart here. I haven't really looked for it anywhere else. I've been using the heavy duty stuff for over 20 years without any problems. /forums/images/icons/cool.gif
