Engine compartment of Daily driver with electric fans
Discussion in 'The Garage' started by cybrfire, Sep 7, 2003.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Just sharing some photos.
    Not the cleanest but it is daily driven. to bad the radiator has a pin hole. /forums/images/graemlins/frown.gif
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Thats a sweet looking engine compartment! Wish mine was filled with that!
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Yeah, I've learned that you can turn off the fans so your fans don't splatter mud all over inside your engine compartment but that doesn't mean the crank pulley won't take over the fan's responsibility. /forums/images/graemlins/rotfl.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You think those two fans will pull enough air? I have a 7 blade mech fan and I was going to add some electrics to that for the trail but do you really think that's enough?
  5. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Well, I can say that the temp stays at about 210 in town so I think it's okay. Seems on the highway the air is deadended a little and it gets warmer. Also there is a pinhole like I said so really hard to say what is going on for sure. I have recently acquired another rad so we will see if that fixes it. They really move quite a bit of air though. I would have to say more than the factory fan did. I still haven't gotten a thermostatic switch to operate them. So far they are hooked up to a toggle. That will soon change.
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    did my radiator have a hole in it?
  7. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    no, I was afraid you would read that and jump in there. Yours was good to go. This is a different rad. By the way it was good doing buis with you.
    /forums/images/graemlins/thumb.gif
  8. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    thats a bad ass set up, what are the fans from or are they after market? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. dyeager535
    26,980
    You need to "skeletonize" that shroud, and make sure your fans are off when moving. You are blocking airflow over what looks like half that radiator, and that is EXTREMELY important when the vehicle is moving over about 25MPH.
  10. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    IIRC I saw some rubber flaps on a VW(?) covering holes in the shroud. At highway speed the air blows through the radiator and shroud flaps. When the fan kicks on the suction keeps the flaps closed and draws air through the radiator. /forums/images/graemlins/thumb.gif
    Also I hope you're using a relay with that fan. In my youth I bypassed a broken temp switch on a Saab 99. It worked great for a while.... then smoke rolled out from under the dash as all the insulation from the wire melted off /forums/images/graemlins/blush.gif
  11. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    They are take offs from the place I work at. Thanks for the compliments.
  12. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I was trying to figure out just how to cut holes in the shroud without getting the fans sucking air from the wrong place. Actually the whole radiator is covered by the shroud. I might just try the rubber flap idea if the bigger rad doesn't clear things up. Ya, I have a seperate relay on each fan. Thanks for the idea.
  13. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Looks good, Kert. Love aluminum diamong plate.
  14. dyeager535
    26,980
    As long as those fans are mounted as close to the radiator as possible, that isn't an issue. Those fans already have an integral "shroud", anything outside of that isn't helping matters. If your fans lacked that outer "piece" that contains the blades, you'd need an additional shroud to keep air flowing through the radiator. With a shroud, you just need the fans against the radiator to make sure all the air they are pulling is from in front of the radiator, not behind it.
    No reason to run the radiator surface area restricted unless its so cold out the coolant won't come up to temp.
