Engine condition, what to check
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Jun 5, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Got a 400 for the Blazer and was wondering what I should check to make sure its all good to go. Was told it had a recent rebuild but has sat for a few months. Anything I should rebuild/replace before I put it in? Gaskets, Carb, etc.? Hoses and vacuum lines are a for sure, doing those right now, and of course new paint. /forums/images/icons/smile.gif Would hate to install it and have it grenade as I pull it out of the garage!! Thanks for the help!! Sam
  2. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    new valve cover gaskets, they are probably dried out by now and will leak oil everywhere. make sure you have the right flywheel also there is more than one type for each size engine or i guess you could change starters. there are other things too, but i'll let the more experienced speak up, i have only swapped one motor before.
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    You can run a compression check on it. That'll check the rings.
    Change the valve cover gaskets, timeing cover gasket, oil pan gasket....all the gaskets on the outside of the motor (don't change the head gasket unless you have to).
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    make sure you have the correct harmonic balancer for the 400 (i'm assuming it came with the motor?). i'm pretty sure the flex plate is the same (if your old motor is a 2 piece rear main seal), so the starter would work as well. i'm not sure about the gaskets or not, but to be safe i'd at least have a look. i'd also prime the motor prior to starting it up and take it easy. did you get a complete motor with intake manifold and all?? depending on the bolt pattern of intake to heads, i'd say everything would/should work (minus the harmonic balancer). however you might have to step up to a bigger carb. or re-jet it for the bigger motor.
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Actually the 400 small blocks used a counter balanced flex plate as well as the balancer. Like they said, a compression test is a good indicator of condition, and gaskets are always good insurance.
    Mike
  6. seslick77
    Jan 27, 2002
    220
    Cool, thanks for the help fellas!! /forums/images/icons/smile.gif BTW the motor came complete with everything. Bought it from K5er Butch who pulled it from his 1ton parts truck. Everything is there including a TH400 bolted to it. /forums/images/icons/smile.gif Onlything missing is the power steering pump. Thats ok cause I have to use my diesel pump anyway for the brakes. Again thanks for the help!!, Sam
