Engine Control Module
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BettyBurb, May 3, 2003.
  1. BettyBurb
    BettyBurb Registered Member
    Dec 14, 2002
    52
    NorthEast Colorado
    I finally got time to install my tranny temp gauge in the dash of my 1988 Suburban. I noticed under the steering column a little box, it has cooling fins on it and I wonder what it is. It looks like it has been messed with before because it mounts to a clip like thing and the plastic on the box is broken for the mount.
    I tried to find out what it is in the chilton manual and it just does not have enough detail, sounds like it might be the Engine Control Module ???
    Anyway, now I am a little worried because the chiltons manual says not to restore the power to the module when the ignition switch is on because it can cause severe damage to the module. Well I had the switch on because I needed to move the auto trans shifter to get room to reinstall the dash. I forgot to turn it off when I reconnectd the negative battery cable.
    I wonder where the ECM is, is it the box under the dash ??? How can I tell if the ECM is damaged now ????
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The ECM is usually on the passenger side, near the heater box, behind the glove box. I'm not sure what that thing is you're describing, but it's not the ECM. The ECM is a metal box with two large pluge coming out the side with a small screw on access panel on it.
  3. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    Yeah, I agree. Whatever you're looking at is not the ECM. The ECM is located almost directly behind and above the glove box, with tons of wires coming out of it, in two plugs. No clue as to what you're looking at.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm pretty sure that little box is the timer module for the delay wiper settings. /forums/images/graemlins/cool.gif
    You'll usually know right away if you've damaged your ECM. The engine won't start. /forums/images/graemlins/shocked.gif
  5. dyeager535
    26,976
    HarryH3 is correct, the wiper delay box is the only thing that you'll find with the exposed heat sink. Only other
    "box" you'll find on that side of the truck is the cruise module AFAIK, and thats bolted to the brake pedal assembly or firewall.
