engine conversion
Discussion in 'The Garage' started by DieselBurb, May 27, 2003.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    Has anyone ever done or seen on of the mid 80's trucks converted from a Chev V-8 to a Pontiac V-8?
  2. dyeager535
    26,979
    2wd wouldn't be too difficult, 4wd brings the question "why bother".
    Truly, it makes more sense, and would probably be cheaper, to just stick with a Chev drivetrain.
  3. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    i swapped in a pontiac 455 into my 84 gmc jimmy. needed to be different. what do you need to know?
  4. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Not exactly the same thing but should be close enough. I ran a 455 Buick in a 77 K5 for a lot of years. I believe that the Pontiac is close to the same dimensions as the Buick block. I ran stock exhaust manifolds and was even able to pull the heads in the vehicle. The biggest pain is getting the block located in the frame rails. Use a bare block and tack weld your mounts first. The tranny is easy. BOP 400 trannies are a dime a dozen. swap the chevy TH400 main shaft and bolt up your Tcase. You then have a lot of torque from an inexpensive engine and tranny.
    Good luck if you decide to do this.
    Mike
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    SF87K5 has a 428 poncho in his, along with a few others. I might do that someday....
  6. DieselBurb
    Oct 8, 2002
    201
    I was just wanting to know about the engine mounting, accessory brackets, etc.
    My 6.2 "boat anchor" has decided that it would rather pass exhaust into the coolant instead of the exhaust manifold. I've replaced the head gasket, but it didn't fix it and I'm tired of monkeyin' with it.
    I found a 77 400 out of a Bonneville that is CHEAP. My books say that it is rated at 180 hp @3600 and 325 ft-lbs @ 1800. Those numbers are better than the oil burning paper weight.
    Any tips on the swap is greatly appreciated.
  7. dyeager535
    26,979
    First off, are you dealing with a 4x4 or not?
    If 4wd, what tranny? Your Chev transmission will most likely not be one of the "universal" patterns, so you'd have to swap the transmission. But with 4wd, you have to swap the output shaft. But if your truck is a 700, the donor won't work, because it's either a TH350 or 400, and the outputs don't interchange AFAIK.
    If 2wd, engine and tranny will just need swapped in place, and thats that. Perhaps driveshaft changes, but thats probably less than $200 if you have to have a new yoke installed and what not.
    Other things to consider...the wiring. Which side is Pontiacs starter on? Olds for instance, is opposite Chev, which means the battery is on the wrong side, as is the alternator. If the Pontiac is the same as Chev, easy.
    Fuel lines are another small issue, depends where the fuel pump is on a Pontiac. Drivers side, you'll just have to cross over. I think most (all?) GM V8's were pass. side fuel pump though.
    You'll have to take the motor mounts out of the pontiac, but don't know if the "height" will be ok in the truck.
    All the accessories would need to come with the Pontiac, I doubt if *any* of the bracketry interchanges, as the engines are completely different than Chev.
  8. DieselBurb
    Oct 8, 2002
    201
    Mine is a 4x4 and all I am doing is a motor swap. I expect that I will have to use an adapter plate to used my tranny.
    If it is like my 56 Pontiac, the starter is on the driver's side. Not a problem since my /forums/images/graemlins/burb.gif is a diesel now and as it turns out, the better battery tray is on the driver's side.
    I can figure something out on the fuel lines.
    I figure the I will probably have to fab my own motor mounts.
    I am figuring on none of the brackets working, so I guess I'm going to have to either find a donor, get them as reproduction parts, piece them together, or make my own.
  9. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    My 428 was in my truck when I got it. It has the pontiac motor mounts and I have a universal TH350 for mine. Most of my stuff is the stock brakets. If you want I can e-mail you some pics of my engine so you can see how it is set up. Just let me know ok. /forums/images/graemlins/thumb.gif
  10. DieselBurb
    Oct 8, 2002
    201
    Cool, send them on. Thanks
