ENGINE CROSSMEMBER DONE! SEPT 28th woohoo
Discussion in 'The Garage' started by jjlaughner, Sep 17, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    (updates down the page)
    For all those that have done the swap and have crossover did you change or modify the engine crossmember any to fit the crossover steering or are you using the bent drag link?
    I was planning on making a boxed engine crossmeber but at this point I'm thinking about just slapping all the parts together to do my body swap onto the new frame, wonding if I should do the crossmember or not. I have crossover parts with a straight draglink to install but I need to order my bushings and get my passenger side knuckle done in order to get a good mock up.
    as always, pics would be good /forums/images/graemlins/waytogo.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: people with the 52\'s up front, question about crossover and engine xmember
    I use a bent drag link. There are a couple pics in my gallery but nothing that shows the drag link. It's a dark color so it doesn't show up all that well.
  3. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Keep the boomerrang steering arm. It's way stronger, more relieable and you can find parts in anytown USA and Autozone!
    But really, I've seen more failures when people convert to COS. Boxes loosening up, frames breaking, front shackles bending and broke end links if not using TRE's.
    Get it together and try it out. Use a steering block or raised arm or offset draglink to get you going.....Good luck
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    How is COS more problematic? /forums/images/graemlins/screwy.gif
    I could not imagine what all i would need to scab together to get enough travel in a stock style sttering set up to get mine to steer. crossover is the only way /forums/images/graemlins/waytogo.gif
  5. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I went the Bent draglink route, Sky sold it to me for $65, so I was all over that like MJ on a 10 year old.
    Oh, and that would be "michael jackson" I'm not sure, or care to see what our resident mj is up to in HIS spare time /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Ford and Jeep seem to be fine with crossover... and Ford had some mighty girly looking knuckles.
    The only thing I'd worry about is the frame.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I agree with you. There isn't anyway to get factory chevy steering to accomadate any type of articulation let alone much lift to begin with. However, the frame is the problem. Even in the factory configuration the frame gets worked back and forth till it cracks and a good part of this force is applied front to back which is the way the frame was intended to handle it. When you go crossover it's just the opposite. Most of the forces is applied side to side or across the frame with a rotational twist on that section of frame which is exactly the way it can't take it. So while crossover alleviates the problems with geometry in the steering it creates problems for the frame. So of course adequate bracing fixes this problem or hydro assist also removes a great deal of stress on the frame. But, all told you are right. Crossover is the only way to go. At least you can steer and beef up that area of frame to handle the abuse. Just an FYI for anybody reading.
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/confused.gif AHHH not this time, the drag link would be about 4" long seeing as how 52's move the front axle forward 3"... PLUS there is a TON of steering bump with the raised arm (I hate the DD steering since I put the raised arm on).
    What I'm planning on is setting up the project truck with crossover on the 10bolt and when I get a D60 to put in I'll swap my 10bolt with crossover over to the DD.
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    New (2000ish) Dodge Rams use crossover also /forums/images/graemlins/waytogo.gif
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I thought they used clusterf' ish steering with a bunch of crazy links (engineered slop, just like Furd TTB)?
    Must be something new, eh? Both my neighbors have like a 98 or 99 1/2 ton and the other a 2000 1/2 ton.
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    dodge steering
    whatever you call this /forums/images/graemlins/dunno.gif
    Guess I should have said a "type" of crossover /forums/images/graemlins/thinking.gif
  12. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, frame is no problem... add a bolt on brace and a weld on brace and then run hydro assist. All is good. If it gives you any grief after those mods, go full hydro... then I guarentee you wont have a frame crack problem... due to steering anyway. lol!! /forums/images/graemlins/laugh.gif
    j
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Having the axle moved foward takes it away from the x-member. It is kinda a self solving issue. I run a bent link just for the angle issues on the DLE's but that is just me. The pic above would be a great way to accomadate the 52's and hi-steer with no extra binding.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think the only reason you say this is that your rig doesn't really have much flex to speak of. Once you soften up that front suspension, trust me, YOU'LL HATE not being able to steer.
    If I had it to do all over again I would have gone full hydr. I could have done it for $100 or less. My friend has all used parts and did his for about $50.
    There is no reason for a high dollar orbital valve if you're talking trail use only. He made his own reservoir, welded a washer to the top of the stock steering pump, then welded in a fitting, and ran hydro hoses to it, the valve, and ram, and was done. 2 gallons or so of capacity, nice cool fluid all the time, and fully hydralic steering off a forklift that works great.
    I have crossover/hydro, but if my frame pisses me off or I find a cheap orbital valve, my crossover will be for sale.
    Too bad I spent $320 on a setup I used for one trail run and then bought a trailer.
    I'm liking my crossover/hydro so far though, it just costs more than full hydro for offroad use only.
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    The straight draglink I'm getting is setup with TRE's
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Thats why I'm getting a crossover setup, buddy is going full hydro with used parts he got free, so I'm getting his passengers side arm, draglink with TRE's and pitman arm in trade for 14bolt 4.56's /forums/images/graemlins/waytogo.gif
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    tomorrow I'm mocking up a new engine crossmember with 6x2x3/16 tube
    need some idea for bracing the steering box though /forums/images/graemlins/thinking.gif
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Re: question about crossover and engine xmember with 52\'s, started new xmember
    Started mocking up my crossmember
    Transfered the design to a piece of 6"x2"x3/16" tube
    Need to find a plasma cutter, I dont know if I cut this cleanly with my torch and there's not really enough room to use the sawsall /forums/images/graemlins/thinking.gif
    I'm going to weld in 1/4" plate to seal off the tube, it will use both motor mount bolts and bolt to the bottom of the frame in the stock locations.
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Lay a straight edge on there. If you have a nice guide you'd be surprised at how nicely a torch will zip that out of there.
  20. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thinking.gif I thought about that withthe plasma cutter but I didn't think about that with a torch /forums/images/graemlins/doah.gif
