engine cutting off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Mar 11, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    this usually only happend when i was in 4wh...but it happend last night in 2wh.
    Ill be coming up a hill, lay into the gas a little bit and the engine cuts off.
    Like if you hit the gas tryin to make the tires spin in 4wh it cuts off...any ideas?
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Well since you were going up a hill with a carburated engine, it may tend to stall. If you are on flat land and slam on the gas and it stalls it could be due to a malfunctioning pump circut in the carb. The pump circut dumps fuel into the engine when the gas is slammed to the floor. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    How long has it been since the fuel filter was replaced?
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Sounds like a fuel filter problem but could just be since its carb. Get a big inline filter.
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Get a big CLEAN filter.... /forums/images/graemlins/cool.gif
