engine cutting out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Kell, Oct 22, 2003.
  1. K5Kell
    K5Kell Guest
    I'm running an 87 w/ a tbi 350. It was running fine until the other day when it started acting like the ignition was cutting out when it would hit around 1500-2000 rpm's. It seems to idle fine. I'm completely lost and cant afford to deal with a shop(im an 18 year old college student /forums/images/graemlins/wink.gif) So if anyone has ideas I would appreciate it. also i'm in bellingham and theres been allot of puddles i have been flying through /forums/images/graemlins/smirk.gif, I did check the cap and rotor but they were dry. thanks for any input.
    -Kell-
  2. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    pull your ignition module out and take to adavnce auto for free testing.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Fuel pump /forums/images/graemlins/crazy.gif
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Before you worry about the fuel pump change the filter.May just be clogged. Cheap and easy fix.
    Check the dist module.
    Scan for trouble codes.
    Does the check engine light come on once in a while?
  5. K5Kell
    K5Kell Guest
    I started it up today and took it for a drive and it seemed to work fine after having the problem for almost a week now. it doesnt throw any codes since I put in a new 02 sensor(about a week before this started). but thanks i'll try to take a look at it this weekend!
    -Kell-
  6. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    make sure your coil wires aren't worn through and grounding out on your air cleaner cover.
    i had similar issues with mine right after i got my k5. i couldn't figure it out for the life of me. went through all the possible fuel delivery issues i could and still came up with nothing. my dad came down one weekend to help me try and diagnose the problem. two minutes into it and right after we pulled the air cleaner he saw where on of the wires had been rubbed through. i couldn't believe i had missed that. anyways, a quick trip to autozone and and no problems since.
    good luck,
    lance
