engine dies when wheel turned full lock
Discussion in 'The Garage' started by tx_sub, Mar 24, 2005.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    This happened today. First time in a while. When I turn the wheel all the way to lock when at at stand still, like in a parking lot, the engine either bogs down and I let off the wheel or it dies. Is it the ps pump straining the engine? 91 sub 350 tbi.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    mine dose it to every once in a while
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't hold the wheel against the stop! :D Seriously, it causes the pump to work very hard, as the steering tries to rip the stops off the axles. Line pressure jumps up well over 1,200 PSI and then the internal pressure bypass valve opens to prevent blowing the hose apart. Back off the steering wheel a couple of inches and all should be well. :cool1:
  4. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    i see. i usually back off as soon as it bogs down. just didn't this time. is there any way to prevent it in the future other than the obvioius don't do it? is it still a problem if you go hydro assist?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah never keep steering fully turned against stops, very bad thing, less you want to have to replace line or pump
    if you think that it dosnt turn far enough before hitting stops then pull the welder and cutter out and modify/relocate them a little but dont get carried away, a little movement at stop is alot at outers of tires,
    good luck
  6. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    A man went to his doctor screaming "Doctor, Doctor I just broke my arm in 3 places"
    Doctor said "stay out of those places"
