Engine Dieseling Trouble
Discussion in 'The Garage' started by sta500666, Apr 16, 2004.
  1. sta500666
    sta500666 1/2 ton status
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    I recently put a stock 76' 350 from a 3/4-ton into my 86' Blazer. The problem is sometimes when I turn my truck off the engine diesels, I HATE it when engiens diesel. I had my timing set at 4 degrees, and then at 8 degrees. The engine dieseled at both settings. I also have the idle turned all the way down, but not sure about the fast idle if that matters. Does anyone have any solutions?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: Timing Trouble
    Well, mine does it sometimes when timing is too far advanced , or mostly when idle is set too high. If you had some bad gas or a day over 90 out it could do it too. Reset the timing for the original engine application , and idle speed too. /forums/images/graemlins/k5.gif
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Re: Timing Trouble
    I struggled with the same thing forever. Only fix was new carb and intake. Never has done it again. It is such a pain and kinda embarassing when your already walking away the the damn truck is sputtering and spitting
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Do ya know the history of the engine??
    If you are idling at about 700 or so and it is still runnin on I would suspect carbon build up.
    Excessive amounts can and will stay hot enough to ignite fuel after you shut it off.
    With that scenerio I rev it at idle to about 3K and with a spray bottle squirt water down the carb, then take it out and run the [darn] out of it.
