engine dip stick tube ?
Discussion in 'The Garage' started by mouse, Mar 19, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'm reassembling the emging for my blazer, just got everything back from the machine shop. This is the first SBC that I've assembled, so far its been very easy. There was am outside and inside tube for the oil dipstick. How does the inner one go back in? Does it need to be there?
    Thanks. BTW can't wait to get it going again. One step over stock cam, high volume oil pump, completely went through the heads - they were shot.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The inner tube does need to be there or there is a chance of the dipstick getting caught up in the rotating crank and rods. Simply drop it in the hole then use a small punch ot screw driver to tap it into the hole until its seated then install the upper tube.
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thanks for the help. I'll take a look and see if I can get it in there.
  4. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Take photos of you doing this because I am going to be installing a new tube and stick soon.
    Adam
  5. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Well basically the lower tube slides in until it can't go any further and the outer tube goes in on top of it. I used a wide screwdriver to "press fit" the lower tube in. It doesn't feel like it will move.
