Engine doesn't crank but no starter click - solenoid?
Discussion in 'The Garage' started by Ben B., Mar 25, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    If it doesn't click when I turn the key it's more likely to be the solenoid or a wire than the starter right?
  2. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Check for bad connection to the battery, check the charge on your battery.
    I have had similar problems, sometimes its as easy as cleaning your battery connections and posts.
    When solenoids go bad a lot of time you get a warning period.
    Make sure you have enough voltage to the starter first.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    More likely, yes. As said, check voltage; bad (loose, corroded) connections could do it. The solenoid is what clicks, so if it's not getting juice or if it's sticky, yep, no clicky.
    My experience is that the solenoids fail due to heat; I buy only AC Delco starters and immediately put a heatshield on them, and I've not had to replace any since I've started that regimen.
    I used to carry a short length of 2x4 with me to whack the starters when they gummed up -- funny, but a PITA, especially in the summertime when the exhaust is hot and you just want to get home.
    -- A
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Also make sure to check your ground, both to the frame and the block. I can't tell you how much time I've wasted troubleshooting starting issues, and it turned out to be a bad ground connection.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    In this order, check battery voltage, clean terminals, check for voltage at the (S) terminal when the key is in the crank position. If all test good then you have a bad solenoid. If everything test good up to the point of no juice to the (S) terminal then suspect a bad ignition switch.
  6. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    add this to the mix..
    Ignition coils can give the same symptoms when they go bad too. if you find yourself with a charged battery and no clicking...I've had igntion control modules be bad as well, when changing the coil didn't solve the problem..
  7. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    Same thing happened to me, used a mallet and hit the starter while someone turned the key...worked for me, then it happened again. Swapped in another starter and its fine. Or you can also try arcing the the posts (or whatever its called). Have to do it my friends heep all the time. Take something metal and touch both posts on the starter which should make it crank (have the key to ON and it sohuld start). If that doesnt work I'd check battery and all that
  8. Ben B.
    Sep 1, 2005
    352
    Central PA
    If I go out right now, turn the key to crank and get someone to hit on my starter it'll start?
  9. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    I had the same thing happen to me, and it was my neutral safety switch. I had that replaced and all was good!
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    It might. It worked for me a few time till I put in another starter
  11. dremu
    Feb 27, 2000
    15,958
    452
    If the solenoid is bad, it may jog the solenoid loose. Do this to go to the dealer or a good parts place and buy an AC Delco replacement starter. Do NOT keep doing this, as eventually it will strand you. Ask me why I know :whistle:
    -- A
  12. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Yes especially because you can think its "fixed" after when it starts fine afterwards for awhile. And it wont break when your home or close, itll break only when your farthest away as possible :rolleyes:
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Why do you keep guessing at it? I told you how to go about checking for your problem. You want to find the problem then fix it, not keep throwing time and or money at it.
  14. Ben B.
    Sep 1, 2005
    352
    Central PA
    I haven't thrown any money at it. lol
    She's a 4 speed so all I need to do is catch it in gear if need be. Just trying to get a good idea of the problem cause.
  15. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Have you tried what we've told you yet? I'm curious if it worked or what the problem was
  16. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Glad you haven't thrown any money at it yet. But if you test as i've said you will find out if you have a bad solenoid or ignition switch.
