Engine electrical problem
Discussion in 'The Garage' started by Big'nBadK5, Aug 6, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    I'm trying to get my electric hooked back up in my K5, and i'm getting the starter in, the problem is: even with the wires hooked up correctly (as far as i can tell) no matter what when grounded the starter turns. the key is not in. and i am totally lost. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif any ideas to what this might be would really help alot. thanks.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The small wire to the solenoid should be switched (ignition turned to start) sounds like its hot all the time. Get a meter or test light helps a lot.
  3. Big'nBadK5
    Feb 9, 2003
    84
    Pjs, Ny
    why would it be hot all the time? i have a digital multi-meter. i even pulled the ignition fuse and it still happens. /forums/images/graemlins/1zhelp.gif
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    check your wires on the starter make sure nothing is crossed. Sounds like maybe that big hot wire from the Batt is either hooked up wrong or touching another wire.
