Engine experts need help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TWISTEDJACK, Sep 8, 2002.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Checked the timing on my 350 tonight, 18 degrees!!! WTF /forums/images/icons/crazy.gif Does that seem too high? I set it back to 10
    and the motor now lacks punch??? /forums/images/icons/confused.gif /forums/images/icons/confused.gif
    Why doesn't it have any power at 8-10 degrees????? I set it back to 18 for the Mud Drags tomorrow. Every motor I have had before would detonate like crazy advanced this far.
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    try checking your plug wires are on the cap on the correctly, thay my over one plug. and check that your distributer is in tdc. hope this helps
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It is not too unusual for a small block to run good with 18 degrees initial advance. You did disconnect the vacuum advance and verify the RPMs when you checked the timing? If it doesn't ping, run it! You may want to check your plugs for signs of detonation just to make sure, especially if you have a loud exhaust.
  4. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Set it at 10 with the vaccuum advance disconnected.....
  5. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Okay, checked the distributor for TDC and the plug wires are in order, checked the plugs they are a nice tan color.
    Check the timing with the vaccuum advance disconnected,
    still likes to run better at 18 /forums/images/icons/confused.gif I hooked my trailer loaded with a 8,000 lb load and pulled a 7% grade,
    no pinging, /forums/images/icons/shocked.gif Set the timing back to 10 and tired to pull the same hill, first gear barely made it. /forums/images/icons/mad.gif /forums/images/icons/mad.gif guess I will leave it at 18 and pull the hills at 65 /forums/images/icons/cool.gif /forums/images/icons/cool.gif /forums/images/icons/grin.gif /forums/images/icons/tongue.gif
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    its probably one of2 things...the balancer has slipped on the hub......or the wrong timing tab on there too....just my .02$ worth..
  7. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    I thought of that, I pulled the balancer off to check it.
    The key way is in good shape. I know the pointer is correct. It has been check at TDC after I checked the
    balancer. Has me puzzled. The only thing that has changed
    in the last year was I put a Holley Projection on.
