engine freeze plugs
Discussion in 'The Garage' started by adamforsythe, May 11, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Is it a paint to remove the engine freeze plugs? Or should I just paint them when I paint my engine.
    Adam
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    paint them. Removing them is easy. Removing them in one piece, just isn't happening. Not anyway I know of doing it. I want to paint my motor before my "freeze plugs" go in. I like to see the brass plugs.
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    If you already installed your new core plugs do not remove them unless you intend on getting new ones. It will not hurt to paint over them, just personal preference. If it is for a show car than they may look cooler with the shiny brass, and if it is in a show car you probably have lots of money so just take those out and buy new shiny ones :D
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Pull em if you are replacing em, stuff aluminum foil in the holes when you paint. If they are new, smear vasoline on them, then wipe them off after you paint.
  5. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    it's very easy to remove them in one peice... just take a hammer and a big flathead screwdriver and beat on one side of it (left, right, top, or bottom) until it turns enough for you to grab it and pull it out. you won't be able to use them again tho.
