engine getting FI... cam ideas?
Discussion in 'The Garage' started by jekbrown, Feb 23, 2007.
  1. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    ok gang. I've got a newish crate 350 in my truggy that currently has an edelbrock intake, rebuilt Q-jet and Edelbrock headers, but is otherwise stock. Here is the plan:
    1. Install TBI (have the parts already)
    2. Get a custom harness/chip from Affordable FI (no emissions, egr, etc... keep it simple!)
    3. remove all the extra BS I don't need, mainly emissions stuff.
    This crate 350 is pretty much your standard 350... no real bling to it. IIRC, its this one:
    Engine Name: 350 LM1
    Horsepower: 249 HP @ 5,000 RPM
    Torque: 304 Ft/Lbs @ 3,500 RPM
    Compression Ratio: 8.50 to 1
    Block: 4 – Bolt, 2 Piece Rear Seal, 4.000” Bore
    Crankshaft: Cast Nodular 3.480” Stroke
    Heads: Cast Iron, 76cc
    Valves: 1.940” / 1.500”
    Camshaft lift: 0.390” / 0.410” Hydraulic
    Duration @ 0.050”: 195° / 202°
    Intake: Edelbrock (forget the part number, 2101?)
    Right now, my rig is completely stripped down for the truggy conversion so accessing the engine to work on it is no problem. Would this be a good time to recam for better low end torque? I am getting a custom chip anyway. If so, which one should I go with? I don't want to get to extreme with it... gotta be reliable... just want a little more low end grunt if I can get it. Alternatively, should I just leave it as-is? What say you, ck5 lounge? :grin:
    j
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    oh yeah, where on the engine do I find the numbers that would identify exactly which engine it is? I seem to have lost my receipts...
  3. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    look on the on the back of the block behind the head to find the casting number
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    rgr, thanks!
    any ideas on what cam to use? I don't really know jack about them.. what kinda lift/duration is a good thing in a cam for a 4x4?
    truck use: trails and rocks... never really do mud or hammer down a lot. Low RPMs is the norm.
    j
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    A mild choice would be somewhere around 206/218 .450/.450 112; A little more power could be had with something like 218/226 .500+/.500+ 114. The more duration the more LSA you're going to want. In any instance, I'd try to keep it above 112, 114 is better. In addition to the PROM tuning, you may have to bump the fuel pressure and/or add an aftermarket regulator if you're going with a cam that is the size of the second or larger. The factory LT1/4 cam(s) are good choices and are available used on ebay, the LT1 HOT cam can also be used. I would consider doing valve springs and 1.6 rockers for more power, too.
    Check Comp's Extreme FI grinds, and Crane's Z-car grinds- Summit sells some similar ones under their brand name for quite a bit less.
    The less cam, the less tuning you'll have to do. If you don't mind tuning and getting a WB 02 I'd get something bigger. Seeing as how you're getting a chip made, you may be able to eliminate most of the tuning right off the bat, and only have to dial things in with the fuel pressure. I just haven't read a single post in any BBS of anyone being able to do that yet. It usually takes several different PROMs and several hours of tuning to dial in a larger cam correctly.
  6. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    As stated LSA is a big deal. I was e-mailing with the guy at tbichips.com about this same question.
    My current cam with carb has 218* at .050" and LSA only 110. He told me the LSA is no good for TBI.
    His recommendation was a cam designed for computer controlled engines and an LSA of 114* He also recommended 1.6 ratio rocker arms for better mileage and power. The only thing is this setup may put the low end RPM higher than you'd like.
  7. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    for a second lets all just operate under the premise that I know nothing about engines or FI systems.... LSA? WB 02? :crazy:
    j
  8. bowtiepower00
    May 11, 2000
    924
    AZ
  9. dyeager535
    26,979
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    thanks much for the links/tips, it is appreciated! Anyone else care to chime in?
    j
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    LSA= lobe seperation angle The seperation between intake and exhaust lobes on each cylinder.
    It helps keep the vacuum up which for MAP setups is very important. For TBI I have always read that 112 is minimum for sufficient vacuum.
    Another thing if you go with 1.6 rockers make sure you have sufficient head valve to piston clearance at TDC. It would suck to knock a hole in a piston:o
    Ira
  12. sandawgk5
    Oct 28, 2003
    6,881
    I guess I should have read the link first eh?:o
    Ira
  13. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    The Edelbrock Performer is a good mild cam. They will send you a chip for free too! I had a different one put in my 383. I will have the specs later.
