Engine gurus-long but please read
Discussion in 'The Garage' started by crazyrc, Oct 6, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Here's my story. Engine is a built 406, blah,blah blah.
    Problem is I have poor idle, and poor power below 3000 RPM. It starts to run better after 3000, but its still not doing what it should. Engine is virtually new. Power is...or was incredible from idle to 6000. This thing would roast the boggers on dry pavement. Now it barely wants to spin them in mud. (until I get the revs up) The engine also runs on after shutting it off...and the timing was double checked. I think it could maybe be overfueling as the exhaust smells very rich. I checked the floats on the carb and set them accordingly. I thought the HUGE fuel pump I put on may be causing thge pronblem, so I also installed a pressure regulator...No better. Please help.
    I'll pull the spark plugs tommorow. /forums/images/graemlins/confused.gif
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    It does have the symptoms of an engine running rich.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    most definately running rich, my truck had a run on problem when i was first messing with the carburetor, i re-adjusted the idle mixture and it fixed it, raise the idle speed a little bit with the adjuster screw, then screw the 2 side screws on the front sides of the carb in until it loses rpms..check for power...repeat until its right..
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Running rich or a huge vaccum leak......
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Which would cause a LEAN condition. /forums/images/graemlins/thinking.gif /forums/images/graemlins/confused.gif
    I am thinking the choke is stuck or something. I'm sure hwen you do pull the plugs you'll find them black and sooty.
  6. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    only refering to the vaccum leak as a possibility as far as the advance on the distrib.......who knows
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    It could be too much fuel pressure,or perhaps if its a holley carb,it might have a blown power valve.Or maybe the scondary butterflys arent opening.Good luck! /forums/images/graemlins/grin.gif
