Engine Gurus, what to do w/ my stuff to make it more badass
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Troopie's Tonka, Nov 9, 2002.
  1. Troopie's Tonka
    Troopie's Tonka 1/2 ton status
    Oct 3, 2002
    284
    Aiken, SC
    I wanna make my 350TBI more baddass without breaking stuff tomorrow. It's in an 88 K-5 silverado, already have hedman headers and K&N. I wanna do more to it, and i know sh$t about engines. What are some moderate additions I can make without blowing my engine tomorrow, but that gives me some baddass extra performance. i've heard terms like: heads,cams, camshaft, cold air intake, blah blah blah, so what should i do and what can my engine take? thanks engine gurus.
    here's what i got, np208, 4.56gears, gm12bolt, and hellifIknow what tranny i have, but let's call it stock for an 88 /forums/images/graemlins/k5.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Good flowing exhaust will do wonders. Vortec heads - if you need to ask what these are, you need to do a search...probably been covered in about 3 different posts in the last week.
    Let me help you with your tranny: I'm going to guess you have a 700-r4. Here are my questions for you: do you have to push in a little pedal to the left of the brake pedal, and then grab onto a metal stick and move it up and down? If so, it's an SM465.
    If no, when you shift into gear - on the gear selector - is there a D with a [] around it. If yes, then it is the 700-r4 like I thought.
  3. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    The problem is is that your engine is computer controlled. What you should do is swap in a cam designed for your computer. A free flowing exhaust would benefit you greatly. Headers, aren't relly required with your engine the cost vs benefit isn't enough until you get some more ponies.
    The vortec heads are a great performance bargain if you want to tear your engine down that far (cam swap at same time to take advantage of extra flow)
    Just take your time and match everything up. ie there is no use using a long duration, wide lobe angle cam with your computer. The computer would have a fit.
  4. Troopie's Tonka
    Oct 3, 2002
    284
    Aiken, SC
    yes, i have 1,2,d,[d] no petal thingy like you said
