engine help
Discussion in 'The Garage' started by adamforsythe, May 5, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I have found with my engine that if I am doing 0-35 MPH and I hit that gas my engine will just rev up and I will not go anywhere in tell I let off a good amount. I am not kicking in the 4 barrel but I will get close to that point.
    What is going on?
    Stats on my engine/truck:
    edelbrock: 600 Carb, Edelbrock EPS intake, accel super coil, Gm preformace
    long block.
    Th 350 tranny, 3.73 gears.
    Adam
  2. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    So what your saying is that your RPM's increase but your speed dosen't ? If so the only thing I would think that could make that happen would be transmission slippage .... Have you checked your fluid level ? If you have and it is ok then it might have some clutches going bad...
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Great, I guess I will check the tranny when I get the engine out. I was going to rebuild it anyways.
    Adam
