engine help
Discussion in 'The Garage' started by ibrakeformud, Apr 15, 2002.
  1. ibrakeformud
    ibrakeformud 1/2 ton status
    Jan 8, 2002
    118
    vancouver wa
    ok i got a 68 camaro and im putting a 454 in it the motor i got came from a guy that had it in a boat. right now its 30 over and only about 5 hours on the motor but since it was in a boat there is lots of sand and dirt in it what should i do? should i bore it some more just get it hot tanked and call it a day or what im all ears i just want to drive it asap but i want it to be done right thnxs david
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Only 5 hrs. on it and already "there is lots of sand and dirt in it". What did he use it for, the boat anchor? I suggest you buy one of the many books on the market that describe how to rebuild BBC's. Read it from cover to cover and learn everything you can about 454's. Pay close attention to the section about disassembly and re-assembly. The price of the book, about $20, will pay itself back many times over. You're probably going to need a complete disassembly, check all your parts, keep everything in order and wash everything good before re-assembly. Also, in your written communication, try and use proper English, you'll find you'll get many more replies if you "speak" the written language well. Most people don't want to work at reading a post./forums/images/icons/smile.gif ImagineifInevertriedtomakeiteasyforyoutoreadwhatIhavejustsaid./forums/images/icons/wink.gif
