Engine ID locations
Discussion in 'The Garage' started by Lotsa_Faith, Dec 31, 2002.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    I looked under the front of the passenger side head, there was not a number there. I need to find out what year engine it is cause I'm changing the motor mounts. Would there be any other places I could find that? The motor has all the SMOG stuff on it, so I'm thinkin '85 or '86? /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It should be there right behind the alternator on a flat spot. It might be covered with paint or grim. there is also a block number behind the Drivers side head that can also give you some clues.
  3. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    No I took off the alternator and degreased that part of the block but nothings there.
  4. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Most the things on my little isuzu are consistant whith bigger gm stuff so this might help. The designation and numbers on my engine are on the driver side just above the motor mounts. Worht a shot right /forums/images/graemlins/confused.gif
  5. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    I just asked my dad about that and he said that on his 327 the engine ids were stamped next to the distributor.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Try then behind the drivers side head. Those numbers are not as accurate but can help you get into the ballpark.
  7. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
