Engine ID numbers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom, Sep 21, 2000.
  1. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Can someone help de-code this engine Number? V0627FJL is stamped at the front near the passenger side head. It was represented to me as a crate engine, 350, originally bought in '95 or '96. Is this the number I need to know is there another one somewhere. Thanks
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think you'll need to find more numbers. Check out http://www.chevymania.com for a list of numbers. That will give you a better idea of what kind of numbers to look for. The block numbers are located on the rear of the block, near the firewall and the oil pressure sending unit. I don't know if that's for all years, though.
    Hope this helps.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    you need the number on the drivers side just behind the cil.head. then you can check the number by http://www.mortec.com
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The book that I have doesn't list any suffix codes for crate motors. I have never seen a reference that includes replacement motors. V = made in Flint, MI
    0627 = assembled on June 27. You could tell a little more from date codes on the castings, at least the year.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  5. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Thanks, I'll look for more numbers tonight. Wish I could find out what the "FJL" suffix means. Doesn't that usually tell the application?
  6. Blazer1970
    1,600
    Old Mission, MI
    Yes, the FJL suffix tells the application. Just not listed in my reference.
    Tim
