Engine Idle and Temp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skroo, Aug 12, 2002.
  1. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    When I drive my blazer to work the temp will get pretty close to the red. It'll only do this when I'm driving 50 to 65 (in overdrive). As soon as I start to drive stop and go it'll run cool like it should. It also ran really cool (170 to 180) when I was in the sand.
    Also, yesterday at the river I ran it through the river up to the headlights and when I pulled out I popped the throttle and it started to idle pretty high. We wired the choke open and reset the idle and it ran OK. About three times after I had to set the idle again becouse it would run to fast or too slow. When I got home it was idling about 2000(i'm guessing). I could'nt back off the idle enough. This morning I cut the wire on the choke and it idled around 2000. when it got hot the choke would'nt open and when I opened it manually the truck would die. Could I have gotten water in something?
    It's a stock 1983 with a 305, auto, and 33's.
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Are you saying that if you are in drive going 55-65 all is cool?
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I thought a stock '83 wouldn't have an overdrive...
    Anyways, it sounds like you have a vacuum leak in the carb.
  4. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    No, when I drive 50 to 65 it'll run really hot.
  5. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    IN the carb? I checked all my vacuum lines and they all look good. I really don't want to rebuild it 'cause I need it tomorrow. Could it be anything else?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you running a fan shroud? what is your thermostat temp? what kind of gm or aftermarket water pump do you use? as for the carb idle do you have computer carb or no computer like my 1983 . if its a q-jet the throttle shaft bushing are shot and no carb rebuild at home will fix that it would have to be machined for brass bushings . try a edelbrock ( mine ) or jet q-jet carb.
  7. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    for the temp thing it might be the trans that making the engire run hot (slipping tcc or bad converter or....)
    do u have a aftermarket trans cooler???
  8. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    It does run a shroud and a stock pump. I have a 185 thermostat but i'm putting a 195 in after I fix my carb. It does have a computer. If I put a new carb in(aftermarket) will I need to change my distributer to be non-computer controlled or can I get away with leaving it alone? I can get a 600 holley rebuilt for $150 compared to the $300 or 400 for a stock.
    I does'nt have a A/M cooler. The trans was rebuilt 20000 miles ago. I don't have any problems out of it but I do have some coolers at work so I can rig one up.
    I'll pull the carb today and see if I can get the new one.
  9. dyeager535
    26,975
    All I'm gonna say is that more than likely, it ain't your carburetors fault.
  10. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Didn't mean IN the carb.. sorry. I meant somewhere the INTAKE is leaking.
    I am not at all familiar with the '83...
    I am guessing the Tranny is not getting a vacuum (Carb leak = high idle), and the tranny is not locking up in overdrive = overheat.
    Just a guess.
    Good luck.
  11. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    I didn't get a chance to work on it until today. I sprayed carb cleanner around the intake and I can see air leaking out. It didn't change the RPM though. I'm gonna change the gasket and see what happens.
  12. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    Thanks for the help dude. I just started it and it runs great. Now i just got to finish my beer break and finish putting all the accesories back on. I'M GOING MUDDING!!!!!!!!!!!!!!!!!!!! /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
