Engine is missing... Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Aug 3, 2003.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    It sounds like the K5 is running on 6 or 7 cyliners... When you put it in drive it almost dies. Could you guys let me know what things I can check on? It has new plugs, wires, cap, rotor, and fresh gas. Someone suggested the injectors might be plugged... It's an '88 with TBI.
    Any suggestions would be appreciated...!!!
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    So, where did it go? /forums/images/graemlins/grin.gif Seriously though, recheck your firing order if you just changed wires. Most of the time it is as simple as that, especially if it ran better before you started the tune-up.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    being tbi, i believe it only has 2 injectors, right? im probably wrong, but run a couple bottles of injector cleaner through the tank if its not your firing order, to clean the injectors, yes that stuff really works,..
