engine # location
Discussion in 'The Garage' started by greywolf, Jul 17, 2006.
  1. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    74 BB 454 the heads say 336781 but i cant find the #s on the block trying to sell motor and dont want to give wrong info.
    thanks in advance:bow:
  2. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Front of the block facing up infront of the pass head will be stamped on the flat surface. On the back of the black between dist and driver head facing up will be cast numbers on the flat surface.
  3. greywolf
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    t0614trh heres part of the vin c4f469736 can someone tell me specs on this motor
  4. dyeager535
    26,975
  5. diesel4me
    Jul 24, 2003
    17,539
    923
    Massachussetts
    heads..
    My book lists the heads as 110cc chambers,used on 74 GM trucks,454 only--have 2.06 intakes and 1.72 exhaust valves..
    "TRH" is the engine code...my book only lists car 454's codes--I have other books at my shop,I'll see if it shows up in any of them and post back later if it does..:crazy:
