engine mount location from 250 to sbc ?
Discussion in 'The Garage' started by R72K5, Apr 16, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    73-up engine mount location from 250 to sbc ?
    i thought 73-up 250 mounts were in a different location on the frame brackets than to sbc engines ?
    but they really are in same holes ?
    or ?
    i guess i am too used to the 72 older trucks where they are in different places for different engines
    hmm..
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yep , same holes.
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Mine had to be moved...
    When I put the 305 in place of the 250 six in my 79 C10,I had to move the motor mounts to the "other" set of holes in the frame--and I must say the 3 bolts that hold them on are about the worst ones to get at on the whole truck.... :crazy:
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    But the frame mounts stayed in the same location - right ? IIRC the frame mounts have all the optional holes for each actual motor mount of that era .
    I know what Ya" mean about the location of the three bolts and nuts - they are aggrevating to say the least !
    Tom
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Yup!
    Yes,I had to move only the "mounts" with the rubber inserts,the frame crossmember needed no alterations...I know if you put a 292 in a truck you need the special frame bracket for the mount on the passenger side(or you can modify the 250 version to work)--the 292 has the frame bracket farther forward,since the holes in the block are different on a 292 VS a 250...
    Those 3 bolts were quite an aggravation during my motor swap--I moved the pads twice before I discovered the brackets on the 305,from a G10 van,were "VAN ONLY! :mad: and weird,no way they would bolt into a C10!--luckily,being the pak-rat I am,I had one set left from the 73 307 chevelle motor I put in my van(I had a hard time finding the "van" brackets too!--now I have an extra set :blush: )...always something to be a PITA when it comes to swapping things around.... :crazy:
