engine mounts location: 350 to 250 ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Feb 19, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    can anyone tell me if the location of engine mounts on 350 blocks are in same place as on 250 blocks- distance from there back to bellhousing flange ? IE: will 250 go in place of 350 without having to move tranny ? i take it engine block brackets differ between the two? 73-up*
    thanks
  2. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    the short answer is no..
    the 250 sits back into the depression in the firewall.very close...
    the V8 sits up further to clear the heads and the distributor
    the crossmember should go into provided holes in the frame, but you will need a shorter front drive shaft..
    and I think there are holes for the motor mounts too
    haven't replaced a V8 with a I6, but I have done it the other way...
    You "can" put SB in place of a 6 on the same mounts, but it is close, and the valve covers are tough to get off..
    A BB forget it...need to hammer the firewall
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    this is on a 2wd, forgot to add that, i should have posted on 2wd board, dang, :S
    i thought i had previously measured mounts to bellhousing distance between a six and a v8 and came up with pretty much same measurement, but cant remember now, which is why im trying to find out now,
    thanks
  4. the professor
    Feb 6, 2003
    130
    Yea, the mount to bellhousing is the same..on all..that is the problem..the 6 is longer, and has nothing on the back of it..
    That is the soul purpose of the indentation in the firewall, to clear the 6cyl engine
    with the 6, the back of the head is where the V8 distributo is..with the bellhousing flange, sticking under the cabl
    with the 8. the distributor and V heads, prevent the motor from sitting that far back, so the bell housing mountin flange is in front of the firewall
    Thats why you have to move the mounts back to move the engine back...
    You may also,not clear the radiator with the engine on the V8 mounts...measure from the motor mounts to the radiator
    I believe the actual setback is about 4 inches..
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so, engine mounts move at frame rails and tranny stays put ?
    i hope so,
    thanks
  6. the professor
    Feb 6, 2003
    130
    No,no..I was not clear...the frame mount move back, and the trans moves back...
    -- /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    crappy,
    thanks
