ENGINE NOISE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74chelsea, Jan 16, 2002.
  1. 74chelsea
    74chelsea Registered Member
    Mar 16, 2001
    39
    I have a 1974 k5 blazer with a 3 year old crate 350. Its fan and belts have always made a little squeaking sound, but recently it has become worse and is accompanied by a sort of grindy, sandpapery, rough sound. It is coming from around the fan or belts or somewhere up in that area. Im unsure if i should even worry, or what i should do. The engine runs fine, im just unsure as to whether or not i should attempt to get it fixed or just understand thats what comes with a 28 year old truck.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Alternator bearings maybe?
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You could start by removing all the belts and letting the engine run briefly and listen. If you don't hear any noises, then put the water pump belt back on, then listen again. Put the P/S belt back on so on so forth.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
