Engine not running to full potential??
Discussion in 'The Garage' started by socal chevy, May 3, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I have been messing with my 305 for a long time now. I just got the carb rebuilt, and it runs pretty decent, except for the fact that it is REALLY SLOW. I know 305's are slow, but mine is REALLY slow. It doesnt want to "take off".... I floor it and it just kinda whinds up slowly. It is not running at its full H.P. AT ALL!! Im lost, and dont know what to do. I want to forget this engine and drop a 350 in there, but Money doesnt grow on trees!! Please help me diagnose my problem!! Ask me any and ALL questions, and maybe I can get this engine running BETTER! :D
  2. camodk5
    camodk5 Newbie
    May 2, 2005
    4
    California
    Have you checked the timing on the motor? Also all ignition wires? Trans fluid? I had a 305 in my 81 blazer in the begining. Ditch it when you can. Let us know.
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Any difference in throttle response when you manually move the throttle at the carbeurator?
    Might want to verify that your carb wasn't put together with "spare parts" left over as well -- check for your jets, float, and take a gander at the linkage between the primary and secondary.
  4. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    The wierd thing is...is that when its idling, its runs like a champion, and The RPMS are smooth, and run high...but as soon as its in gear it all goes POOP.
  5. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I checked all of that and it has new wires.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like you may have a clogged cat convertor. If you are still runing the old stock 84 convertor it Might be time for new exhaust.
    Also
    How old is the fuel filter?
  7. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Mine's no dog...
    I have an 86 305 from a G10 van in my 79 C10 pickup,(longbed too!)--I was actually pleasantly suprised at how peppy it is!--but compared to the 250 six it had before,I guess anything would feel faster! :blush:
    Yesterday I drove it 130 miles round trip to mty sisters and picked up an engine crane,motor stand and a lawnmower her husband wanted me to fix(he gave me the crane and stand,a guy he works with was going to throw them in the dump! :laugh: )--despite heavy rain on the way home,and a headwind,I still squeezed 16 mpg out of it,going 65-75 mph!....
    Yours might have low compression,or maybe weak spark if it seems sluggish under load--might check the coil or try another one(make sure the color codes on the wires match!--the coil,module,and pick up coil are a matched "team",from the factory a spot of white or yellow paint is on the module,and the wires on the pickup coil and ignition coil must match--if you swap in the "wrong" one,it will still run,but have much less spark voltage and that will reduce power)...Also as suggested your timing might be retarted,or possibly the centrifical advance weights under the rotor might be rusted in the retarted position--twisting the rotor,it should "snap back" when you let it go if the springs and weights are working right...
    I recently switched my vacuum advance hose to manifold vacuum instead of ported vacuum--after yesterdays run,I think it did give better mileage,and the idle is MUCH smoother now too--I think I could give it a few degrees more advance without it pinging,I might try it--anything for more MPG!!--gas sucks at 2.28 a gallon!--but I went 130 miles on 8.3 gallons,not bad for lousy weather and loaded down some..but this 305 is the first chevy I've had that runs better on manifold vacuum rather than ported!....
    In my truck I think it might have fairly low rear end gears,that always helps acelleration(I havent looked at mine to see what ratio it is yet!)---if you have 2.56 or 3.08 gears,it will be a dog with ANY motor,but especially with a small one like a 305...GM did that a lot in the 80's,a dinky motor and tall gears--great for cruising at 80 mph,but doggy on hills and take offs..
    You also might want to check your engine codes and make sure it really IS a 305!--one friend complained his recently installed "305" was a dog--after I spent a whole afternoon checking things for him with no improvement,I decided to try looking up the code so I could look up the timing specs--it turned out to be a 267!!,from an 81 malibu!.(and timing it didn't help much!).. :blush: :crazy:
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Brand new cat, brand new muffler....
    Fuel filter brand new.
  9. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    2.28 per gallon...thats nothing.... try 2.57 for REGULAR in Cali!!!!
  10. 78jimmygirl
    78jimmygirl Registered Member
    May 2, 2005
    53
    Auberry, California
    Or 2.80 per gallon for regular in my little town in Cali unless I wanna drive 25 miles to Fresno.
