engine oil?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1st timer, Dec 13, 2000.
  1. 1st timer
    1st timer Registered Member
    Nov 26, 2000
    27
    florida
    is 10-40 to thin an oil for an engine with over 160k miles if it is what do you guys recommend
  2. Rayven90
    Rayven90 Registered Member
    73
    FT Lupton, CO.
    I have 152,000 on mine and I still run 10-30 with about 50 psi on the guage. I also have Fuel injection so I need that thinner oil when I first start up.
    Ray
  3. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    I've been using 10-30 Penzoil since brand new. This AM though when really cold...could hear what sounded like a main bearing knocking for a bit. At 180,000, I know I'll be shopping for a motor before long.
    Would you guys recommend a 5 wt. for the above symptoms? Today was the first time I heard it!
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hey Bob- my truck does the same cold start knocking when my oil starts to get dirty and the filter plugs up a bit. Normally an oil change will fix it right up. FYI, it's been hitting -20 Farenheit for the last few nights up here.
    I've been running 10w30 both winter and summer for 8 years.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Can you even buy 10-40 any more? That stuff got a bad reputation several years ago because of all the chemical additives they have to add to get the 30-point viscosity spread. The additives were caking onto the piston rings and causing them to break prematurely.
    I run Mobil 1 pure synthetic, since they don't have to use additives to get it to behave in different temps. Seems to be great stuff!
    http://ThunderTruck.ColoradoK5.com
  6. Channing74
    Channing74 Registered Member
    Dec 14, 2000
    77
    Southwest louisiana
    Down here in louisiana we dont worry about extreme temps other than heat so I run 30w to keep the valve guides from leaking so much. But when I replace the motor in a couple of months I will be going for Mobile 1 ......
    Bigger Is Better
    Channing74
  7. mudpuppy89k5
    mudpuppy89k5 Registered Member
    Nov 3, 2000
    44
    Marietta, Ga
    I've been running Castrol straight 30W in my '89 since it was new. Blazer has 200,000 miles and the engine doesn't leak or burn any oil. I ran the 30W in a '85 K20 before I bought the Blazer and in a '73 Z/28 before that. A buddy and I had a boat a while back with twin 350 inboards. We ran the same 30W Castrol and PF-35 filters in it. I also put the 30W in my lawnmower. I guess you can tell I like it.
    The only problem I've had is that the 30W can get pretty thick on cold mornings. In the past, I've run Castrol 20W50 in the winter months. A friend of mine suggested Shell Rotella-T 15W40 which I'm going to try this year.
    I've had an occasional knocking sound when I first crank the Blazer for quite a while. I tried different oil additives and it didn't seem to make a difference. It hasn't gotten any worse and still runs strong, so I quit worrying about it. I'm planning on building a four bolt main 350 or, even better, a 454, so that problem becomes moot.
    John Perry
    http://www.mudpuppy.coloradok5.com/
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i also run 30w in mine with no problems
    s.smith 77blazer lookin 4 mud
  9. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    I use 10W30 in the winter months and 20W50 in the summer months. 117,000 miles and no problems...
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Don't run the Mobil 1 in a fresh rebuild. It's too slippery to let the rings seat themselves correctly. Run a good grade of standard oil for the first 10K miles or so and then go to Mobil 1.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I run Pennzoil 10w-40 in mine and never had a problem at 134K
    90K5
  12. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I also use 10w-40 and never had a problem.
    If it ain't a Chevy, don't raise it up!
