engine or tranny?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 15, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I dont know a whole lot about his kinda stuff so maybe you can help me. I am driving down the road and when I hit the gas while going about 30mph the truck sounds like it is downshifting kinda like going into 1st gear while going down a hill and the truck starts to slow down but I didnt put it into first gear on the highway. If you understand this question or need more infop please reply.
    Brian
    1985 GMC JIMMY
    It has a th350 and it has a wonderful 305<P ID="edit"><FONT class="small">Edited by JimmyJuneau on 08/15/01 07:51 PM.</FONT></P>
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    post again with engine and tranny sizes
    "before any body gets excited"
    and if it's a th350, i would check the modulator, copy that, over? otherwise i don't have a clue. [​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Sounds like you're punching the kickdown on the tranny, and the engine should start screaming and truck move faster. I think it might be a 700R4 seeing as how your truck is an '85, but I don't know.
    Also, on my S10 after it got a new '85 700r4, at some points before the TV cable was set right if you punched it while moving it would just come out of gear altogether, then slam back in when you let off the gas a little. That might be what you're having.
    But, like chevyfumes said, more info I.E. tranny and engine would be helpful in figuring it out.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
