Engine Painting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MILOLGJC, Dec 3, 2002.
  1. MILOLGJC
    MILOLGJC Registered Member
    Sep 27, 2002
    29
    FL
    We want to undertake an engine painting foray on our 76 K5. Does anyone have any hints for a successful paintjob? Also, any special hints about priming and prparing the surfaces would be great. Also, any particular brand of paint would be great. One last question, does anyone make a Chevy orange in a can that can be used with a paint brush? Everything I have seen to date involves a spray can. Seems as though a paintbrush would be easier in some instances. Thanks!
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    use the stuff in the purple bottle, "Castrol super Clean" to clean the block... DO NOT GET ON ALUMINUM!!!!!
    Then Use Brake parts cleaner to clean the rest, then paint... use a wire brush with the castrol super-clean and it will eat the grease away!!!
    Use high temp engine paint, paint several coats, allow to dry in between...
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
  4. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Ive got the POR Orange on mine and it kicks...took it 2 days to dry complete..its like 85 percent solids /forums/images/graemlins/grin.gif
    And it's brushable...but we sprayed it
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    4 Months later...still Orange
