engine pan magnet ?
Discussion in 'The Garage' started by R72K5, Jan 1, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i want to put a magent on my oil pan sump, externally, what can i use, what has anyone else used that worked well ?
    thanks
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Harddrives have big time strong magnets in them. Find a junk old computer and smash the hardrive apart and steal that magnet.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I used an extra magnet from a tranny pan (round one in a 700r4) and used epoxy to glue it to the pan. I put it on the back side of the pan close to the bottom to help keep it from getting ripped off. I may put it inside when I build my 383 instead of on the outside.
    I've also been told that the best place is actually on the bottom of the filter so the debris gets removed from the system on a regular basis.
    After some thought that may be the best place for me to move mine too as well. /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have billions of junk HDD's here, you cant take them apart cuz the freaking screws are japanese crap
    thanks
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hum 700r4 magnet, hmmm, too bad lal my 700r4s were stolen...
    thanks
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you don't own a grinder?
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lol good point, i have access to one, humm, where at in the HDD is the magnet ?
    thanks
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    haha I'm trying to figure this out as we speak. I was ripping an old junker apart(mine use phillips). One screw won't come out though
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well i got it all apart, i just drilled all the screws haha, the magnet is strong but it is way too small to use for oil pan, its tiny only an inch long /forums/images/graemlins/frown.gif you might as well give up anyways
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Why don't you just use a magnetic oil pan drain plug? I have been using those for years. Whenever you change the oil, you can see what kind of debris it has collected. /forums/images/graemlins/thumb.gif
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cant afford one, been out of work way too long
    thanks
  12. dyeager535
    26,980
    I'm sure you found the right magnet, it's on what I believe is the head assembly. Whne you get the HDD case open (for everyones reference) you'll see it resembles a record player. The actual plates where the data is stored is not where the magnets are. They are located where the "arm" pivots, in the corner of the case.
    1" isn't too small, all factory magnets I've seen, and magnetic drain plugs, are all smaller than this, and weaker to boot. I snapped one onto my oil filter. If I had a bunch of them, I'd snap a few onto it if I was really worried about it.
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i put the one on my pan so far, i want to take apart a coupel more old HDD's and put some more on the pan too.
    cool
