Engine ping ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Sep 25, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I've had a loud pinging coming from the bottom of the K5. The pinging is really LOUD when the K5 is in Park or Neutral,but in drive or reverse it almost goes away.It's a 350 motor and a 700r4 tranny with 208 transfer case.Anybody have a clue? All oils are full and clean
    Freedom is a state of mind
    <a target="_blank" href=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</a>
  2. dyeager535
    26,978
    New tranny? I know there is a problem with one of 700-R4 pump valves(?) that will cause some sort of noise, but its more a buzzing from what I've heard of it. Thats a way out idea, but that problem is only supposed to occurr in park and neutral as well. there is are-designed valve, but I guess you can still buy the one that made the noise, so if rebuilt, that could be a noise maker...does it sound like its coming from that area?
    Probably something much simpler, or at least I hope!
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Are your flywheel bolts to your stall convertor loose?
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    Replies to both=No
