Engine pinging when engine is warm... any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jun 18, 2002.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    When my engine is cold it doesn't ping, whent it's at about 120 degrees it starts to ping just a little bit, when it's at 205 degrees it pings non stop. I just adjusted my timing 2 days ago and it's right on 8 degrees which was the factory specifications. Should I take my timing down to 4 degrees?? Do you have any other ideas as to why it pings when cold but when the engine is warm I can look at the gas pedal and it will ping. It's really starting to tick me off.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    When you set the timing, Did you disconnect the timing bypass wire? Its a tan and black wire on the firewall by the brake booster. If you time it without disconecting that wire the timing will be way too far advanced.
  3. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Yes I did. Should I disconnect it then turn the truck on or should I turn the truck on then disconnect it. I turned it on then disconnected the bypass wire. I wonder if that might have something to do with it?
  4. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I always disconnect it with the engine off. Then set the timing. When it is disconnected the "check engine" light comes on. When it is reconnected the light should go off.
    You may also have a problem with the Knock Sensor. Check to see if there are any trouble codes stored. A bad knock sensor will put up a code 42 or 43
  5. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I did have an issue with the knock sensor a while back but replaced it 2 weeks ago, I have not had any error codes listed since I replaced the knock sensor. I'll disconnect the wire with the truck off tonight and try to adjust the timing again. Thanks.
  6. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok... I even took it down to 3 degrees and it still pings. Any ideas?
  7. Khi5in
    Khi5in Registered Member
    Mar 19, 2002
    46
    Medford Massachusetts
    Assuming your fuel injected try a higher octane fuel and or running injector cleaner through your system. Doesn't sound like a timing problem or it would do it cold too. A cylinder compession test and inspecting the plugs will give you a better idea wich cylinders are getting too much fuel or not enough.
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I'll try some higher octane but I already use 89, and I run the cleaner about every 3 months.
  9. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well sir, you've just said exactly what your problem is...8 degrees. TBI motors are timed at 0 degrees with the wire unplugged and the computer takes over from there.
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Are you sure? My manual and the little sticker under the hood both said 8 degrees. I'll try 0 though.
  11. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Really?! Usually they some crap about disconnecting that wire comming out of a harness by the bulkhead, yada yada. They all looked the same, 0 degrees. It is the original TBI motor with the little biddy distributor, right?
  12. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    The guy I bought it from told me it was replaced but I don't beleive him. Anyone know how I can tell if it is the original? But yea it says 8 degrees on the sticker.. I'll probably still try 0 degrees.
  13. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Hmm, it may have had some battle damage and had an older front clip put in. The bottom of the sitcker on there should say something about conforming to emissions standards and then the year. Regardless, 0 degrees is what it wants and the computer determines where to do from there. I'd change the knock sensor too because it should have picked up on the pinging. Good Luck
  14. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I just replaced the knock sensor though. I was also wondering why it didn't pick it up. I did finally get a check engine light today when I was driving it so I need to see what the error code is.
  15. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok... so I was reading around on some other sites, and basically we set the timing to 0 (according to you) and the knock sensor will adjust it as needed (according to other sites). Will the knock sensor ever advance the timing or does it just retard it?
  16. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    The knock sensor ... senses knock. The computer then adjusts (retards timing) until knock goes away.
    The computer will advance the timing (depending on programming) given certain conditions, RPM, engine temp, 02 sensor, fuel, and knock sensor.
    Check your codes, and see what needs to be replaced.
    You should also get a code if the base timing is wrong.
    Good luck.
